If you're going to be in there anyway, you might want to swap out the torque converter clutch solenoid, and the accumulator valves if yours has the plastic
pistons. The bore on the TCC solenoid passage can wear, and they make a replacement kit that's a slightly different size to fit past the areas that normally wear. There are some places that bore out the shaft and put a slightly larger piston in. The accumulators were originally plastic, especially on earlier years, and the plastic can fracture.
Oh..and they make a replacement separator plate that's slightly thicker than original to prevent one of the ball check valve balls from wearing through.
There's a vendor on ebay that offers complete kits and even rebuilt valve bodies (ctpowertrain). You might want to look at what his kit contains and see if you want to replicate that parts list if you haven't already started.
Good Luck!
Chris
