DIY Endlinks
Matt
4,023
Who's got the hook up for making your own endlinks. I've got two that need to be replaced again and think it's time to make ones that won't fail.
I know on ORTB there's the heims joint ones, is there another type or is that it?
Concise instructions would be appreciated.
SnowBlazer
5,775
Colorado Springs
Mason over there makes em for like 100 bucks a pair if you're like me who doesn't bother doing anything yourself. :tongue:
There should be a write up floating around on how to make your own. I'll try to find it when I get back from breakfast.
Torker
36
Udall,Ks
I ordered those but the bolt /stud was only about 3/8" Mine to be appear to be about 12mm . I still need to find some adj. end links since I installed Eibach springs my sway bars are in a bind.
I could likely make some. I did mine as bolt on and not quick disco. Simple as cutting the all thread and bolting them together that way and easy to tighten ot remove with a 3/4 socket and wrench.
i did mine like this awhile back
Firebaugh86
