1. We are working on the forum's attachment system. Attachments and avatars will be intermittently affected over the next 24 hours.
    Dismiss Notice
Direclink controller
Discussion in 'Towing' started by Frazier, Feb 12, 2017.
  1. Frazier
    Frazier Member
    21
    24
    Curious as to if anyone has used this controller
    https://www.amazon.com/DirecLink-DL100-Brake-Controller/dp/B006C2CWWY
    I love the concept. Fully integrates with the vehicles computer and brakes rather than be inertia driven. I could also unplug it when it's not in use, and not put holes in my dash.
    Also, how does the factory cooling system (5.3L) hold up?
  2. Mooseman
    Mooseman Moderator
    9,675
    4,346
    It's an interesting design.
    The stock cooling is fine as long as the fan clutch is working properly. It can look like it's fine but when you add some heat, a load and A/C, she'll get hot and A/C won't work well. It's the same electro-viscous clutch as the 4.2L up to 2007. 2008-09 used a thermal clutch.
    How to test the electro-viscous fan clutch
Share This Page
