- Aug 24, 2014
- 189
Hey everyone, well I found tonight that my cruise control simply is not working at all. No light, no throttle takeover. I have tried to troubleshoot based on some information on the site here but here are the recent changes that have been made on the truck:
1. LED taillight conversion with a Novita LM487 LED flasher and Phillips 3157 LEDs in the stop and turn lights in the rear.
2. Oil change
3. Serpentine belt replacement
4. Replace transmission cooler lines
5. Tire rotation
6. Throttle body cleaning
Now based on information on the site, I have backed out of the LED replacement and put the normal bulbs back in temporarily but that did not solve it. No bulbs are out in the back of the truck, including the center high mounted stop light. I tested the brake lights and they do work normally. I scanned for codes and nothing. The only other thing wrong with the truck which I have not bothered to fix yet as this happened last week is a failed TPMS sensor, therefore I get a "Service Tire Monitor" alert on the dashboard. Is the TPMS system one of the triggers for disabling the cruise control? Which fuses should I also be checking, I realize that it may or may not be like my 98 Jimmy which has a dedicated cable driven module for that but the Trailblazer is fly by wire. Thanks
2. Oil change
5. Tire rotation
