- Dec 5, 2011
- 77
I've had the same issue for years now.. I've gone through 3 water pumps and 3 fan clutches. The last water pump and fan clutch I put a month ago and I decided to go oem and got AcDelco. My mechanic said it was again. But I knew it was not.. I believe that it's the timing chain cover that has a tiny little crack by the water pump. (AGAIN I THINK) So I'll be sending to mechanic to look at again.. we'll see.. I'll say this the AcDelco fan clutch is way better that Dorman brand I've gotten the past 2 times. What can it be? Can it be the Timing chain cover that might have a small crack where the water pump is, when it was removed and replaced years ago maybe the first one i did? Should I get a digital inspection camera? This coolant leak is pissing me off..
