Coolant burning/boiling type smell, everyone once in a while.
c good
533
does it have trouble defrosting the front window? If the window has a hard time clearing itself while in defrost (which turns on AC automatically as part of the drying process) and has a tendency to re fog quickly, then it's still a leaking heater core...or hose connections leaking that go to it. HTH c good
Mounce
13,667
Tuscaloosa, AL
christo829 said:
I had the same intermittent smell and slow loss of coolant from the reservoir, along with wet spots by the cap. Turned out that the o-ring inside the cap was no longer sealing consistently. Replaced the cap, and the smell, loss and wet spots went away. When I compared the old and new caps, the o-ring on the old one was very slightly flattened.
Good Luck!
Chris
I was also thinking caps. Maybe coincidentally both of his caps are wore out.
C-ya
1,098
c good, that is my problem here lately. Sucks! I keep a container of no fog wipes in the truck now. Doesn't really help...
Oddly enough, my radiator cap had a slight wet spot there at the neck where it attaches. Not much, just a tiny bit, but weird. I'll check a new cap out as well. I just had to add fluid to my reservoir.
Reactions: 06TrailblazerLSS
06TrailblazerLSS
93
Anyone know both part numbers of the caps and the cheapest place to order them? Can I use any ordinary 3-4" hose clamp?
RockAuto should be a good place to find part numbers. RA or Amazon should have reasonable prices. Unless you're running drain pipes, 1½ - 2 " clamps should work.
triz
746
Funny...I just looked at mine and I'm also leaking coolant. Appears to be coming from the cap.
Did you confirm it? I thought I had a leak from the cap. It ended up being a small 1 inch crack in the radiator seam near the neck.
Btw I bought some upper and lower hoses from rockauto on clearance. Goodyear too.
Spong
59
C-ya said:
My heater core is leaking, I think. Coolant smell when the heat is on, not bad, but enough to know it is there. I'm not ready to spend the money to have a shop do it since it is (supposedly) not covered by my aftermarket warranty. I found a thread from somewhere linked on these boards that showed a step-by-step R&R of the heater core. Yeah, that'll be a fun day, and definitely not in the winter!
Just curious if you've replaced it yet?? I noticed yesterday my 06 5.3 w/93k smells of coolant. I've been driving it the last few days because it needed exercise. I checked my records and I had barely driven it 200 miles since the oil change in November so I've been driving it. I noticed the coolant smell for the first time yesterday.
I did notice last summer that when I parked the TB after driving it, that it would drip just a tiny bit of coolant on the garage floor behind the passenger front tire. Upon closer inspection, it was coming from a drain tube which I think attaches to the heater box. This would make sense because I didn't use the heat until just recently and smelled it. I wasn't smelling anything during the summer months. I'm guessing the heater core is leaking inside the box and it's draining. I've been watching the coolant level and it's staying full though.
So now I'm debating if it try replacing it myself or paying to do it. I'm fortunate that I don't need to the TB so if I want to take my time and tear it apart in the garage I could. I'm just not sure what specialized tools I might need. I cringe thinking about a mechanic tearing my interior apart.
IllogicTC
3,452
I suppose it's one of those "on the one hand... on the other hand..." scenarios.
Scenario 1 is you do your own heater core R/R. The big thing here is it's usually a very-involved process. The labor estimator books state it's a 5.2 hour job. I'm looking at the actual R/R shop procedures, and you have to remove the entire dash, and disconnect the refrigerant lines and heater line quick-connects to pull the HVAC module assembly out to access the core. This means draining the coolant (easy), and emptying the A/C system (not easy, scavenging refrigerant requires special tools and very expensive shop equipment, releasing refrigerant in the atmosphere is illegal).
On the other hand, putting it in the hands of a mechanic is going to be very costly (see labor hours above) and you have to trust they know what they're doing. The best choice would be to find a trusted and competent mechanic in that case.
Spong
59
Yeah, I've been reading up on it and it's a long process, the entire dash and center console have to come out. I'm not really worried about that so much, it's the AC lines I'm concerned about. I'm worried about causing damage disconnecting them or contaminates getting into the system. I supposed I could have a shop draw the system down and then recharge when I'm finished.
TB2004
57
I've had this problem for a while, found water pump was leaking, replaced it, thermostat and temp sensor. But still have the smell, mostly drivers side. I do have rear a/c - heater tho. I have sniffed around engine compartment and it is on drivers side for sure. Thermostat and sensor not leaking. Have not been able to get underneath to find the hoses to rear heater. Are these metallic or rubber? Has anyone had to change these hoses before? There is no visible sign of a leak, just the smell.
Mounce
13,667
Tuscaloosa, AL
Sorry, just now saw your post.
And truthfully, I haven't even looked at it again.
06TrailblazerLSS
93
I still get a smell every now and then but not as bad as before it seems.. and no more leaks up front with an extra clamp and new reservoir caps. Just thought I'd update.
Reactions: C-ya
C-ya
1,098
Sorry - I just noticed this the other day. Not sure why I didn't pay attention to the quote notice.
No, I have not done it yet. It is getting more annoying by fogging up my windshield - but only the driver's side. Well, it fogs up both sides, but when I hit Defrost, the passenger side clears right up. Seems like I'm having a flow issue, too, where the DS is getting less CFM than the passenger.
I'll have to pick a weekend, clean out the garage from the bikes, mowers and other summer residents and have it available to push the truck into if needed and get to it.
jvest
