Complete Overhaul?
STLtrailbSS
So I Will be sending off my Taxes tomorrow and I'm anticipating with the return to perform a complete overhaul/tune up on the SS I was just wondering what you guys would consider any additional jobs heres whats on the agenda. Im right at 70k
Synthetic Oil w/ K&N gold filter
Spark Plugs
Plug Wires
Rear Diff Fluid
Transmission Fluid
Belts
Will Probably be switching rotors and pads to ceramic
Revive the CAI filter with K&N kit
Thats what I have as of now I'm kind of drawing blanks Add anything you think of. Thanks for the help in advance.
Boricua SS
3,080
Ohio
sounds like your typiical 50k-100k maintenance as far as fluids go... through my readings, i thought our spark plugs can go 100k.. so maybe you dont need to mess with those just yet? :undecided:
but i would definetly do the diffs/trans fluids... especially the trans, as those are the weak points for the SS' and you'll love the ceramic pads.. zero brake dust up front :yes:, once i made the switch, my wheels stayed nice and shiny...
91RS
Clean the throttle body. Also don't forget about brake fluid. Make sure to use good full synthetic gear oil with limited slip additive. The TBSS diff. calls for the Dexron LS Gear Oil that the Corvettes use.
jonnnnyj
