- Jun 22, 2014
- 1,576
Ok guys and girls, I been scratching my head for a while now and can't figure it out.
My 2002 TB LTZ with ECC (ACC) got no heat blowing from vents when turning right at normal speed. Going straight or turning left no problem. Engine temp is normal, checked with my Tech 2.
In summer time the AC dosen't cool as it used to as well, and I checked it full of freon and working as it should. Clutch fan is also working as normal. I think it's related to my no heat problem.
Best way to describe it is like the blend door swing fully open to fresh outside air when you turn right and then when you straighten up or turn left the blend door swings back to closed position.
But after looking in parts catalog on how the doors are mounted, all of them are mounted longitude and none is mounted latitude. Correct me if i'm wrong?
Anybody heard of this before??
