- Jan 16, 2013
- 430
I have a squeal coming front passenger side wheel. It sounds like "e e e e e" increasing with speed. And the squeal stops when the brakes are applied or when turning left. I have cleaned and lubed the slide pins and replaced and lubed the anti rattle clips.
The rotors and pads have about 6 months and 15,000 miles on them. And the pads appear to be evenly worn. Also the shield behind the rotor does not appear to be rubbing. And there is no pulsation When braking.
Any suggestions? My only guess is a bad caliper...
Also the noise stops for a little bit if I do 2 or 3 "panic" stops (abs activated).
