avital 5303 w/ remote start thinks my hood is open
crxman91
3
My remote start stopped working today. On the keypad it says inhibit and it shows the hood open on the screen when i try to start it. I took it to best buy and they had no clue how to fix this. Any ideas? 07 TB LT
kickass audio
955
Maybe they programmed the hood switch wrong, if they even installed it. I know when I went to get my viper 5901 installed, the install shop didn't hook up the hood pin. Hell, with my parent's cars they didn't get the hood pin installed at all. I bitched about that and said its nice for the alarm feature and really great for if someone hit remote start while you are tinkering under the hood. They put it in for free but brought up the idea of a mercury switch instead so its a sealed unit that can't rust away. The hood pins that your alarm came with work but they corrode over time and can make false readings.
First thing to try is to see if you can find the hood pin when you pop the hood. Some places put it on the fender edge, others will put it on the front support rail, some put it on the lip that is right below your wiper cowl. Try to check those areas for the pin. Once you spot it, try to remote start your truck with the hood up, if it starts, that means they didn't program the switch polarity right on the module for your remote start and its a quick and easy fix. If it doesn't start then try to either push the switch down as far as you can or disconnect the little wire that is pushed on the pin. If after doing that you can start it, your pin is either not getting pushed down far enough with the hood down to disengage the safety feature or your pin is not making good contact and needs to be cleaned up.
crxman91
3
I've had the alarm for about 2 years. The hood pin wire has never been hooked up and there is no pin under the hood. The installer told me that it reads the signal from the computer
kickass audio
955
lmfao! There is no hood pin on our trucks unless you put one there. Maybe you have one of the wires that is the sensing wire for the hood pin is shorting out to ground. Try and look under your dash by your pedals for loose wires. They 99% of the time have a rats nest of wires down there where it is hooked up.
MAY03LT
Delmarva
Can the setting for the hoodpin input on the 5303 be changed from normally open to normally closed?
chirobo1
