An incompetent goofball or a liar. Either way, they owe you a re-do. Sorry you missed the previous discussions about it. I can do an approximate toe-in on a trail 20 miles from pavement when I break a tie rod end and take the 15 minutes to change it.MTouz said:..the sales guy pretty much told me that just the toe could be adjusted. ...
the roadie said:Did you confirm for yourself that both sides inner AND outer were indeed bad before the swap? Crooked shops love to lie. As you now know.
MTouz said:Update....I've been driving around as it is after the crap alignment. Scheduled an appointment with a shop that specializes in suspension and front end work. The guy over the phone seemed very informative and kind of laughed about the shop I took it too. I didn't want to go back there because of the service "vibe" I got from the salesmen. So tomorrow TB goes back in!
On another note....with the alignement off would it make the front sound almost like roaring kind of like a bad wheel hub? Kind of know what a wheel hub sounds like goin bad, as I replaced driver side like 6 months ago. I can't tell if its something with the hub or the alignement. I do know there was no sound before the lift.
Thanks
Mike
Couldn't agree more. The shop I went to told me I needed LBJs before they would do anything. They wanted $140 per LBJ (ACDelco 46D2296A) and $180 to install them. I told them I would do it myself and bring it back for an alignment. I was able to get the same part off Amazon for $20 a piece! Rented the 23 piece Ball Joint Press kit from Advance auto and installed them myself.seanpooh said:Everything can be adjusted to spec if you go to a shop that actually understands.
I went to belletire, told me the same thing about caster and camber cannot be adjusted.
Went to the dealership the next day, they did all the adjustments spot on. Took it back to belle tire with their paper work and got my money back no questions asked. The manger also looked like he had something shoved in a place where the sun don't shine.
I still go to to do a safety inspection to tell me if my tie rods or wheel hub bearings need changed since they have lifts. Even though their labor cost is $20/hr, their parts cost 2-3X retail, so they make more than the dealership. Imagine paying over $300 for a wheel hub bearing that's generic but only $60 for them to install. I asked them if I bought my own parts if they can install it, "we cannot do that."
There is a reason why some places charge a cheap price. Then again, the dealership isn't the most perfect place either. They charge $90 because I have a truck and it requires a "4 wheel alignment." They also didn't torque my LCA bolts to spec so when I braked really hard, the wheels went in this one time. I just get so tired with these places.
So all in all, I remove my front sway bar and carry along the spec torque sheet before an alignment and tell them how to do their job.
Because you did something different from other people. Not surprising. They'll tell you everything you've done is "wrong" and tell you they have to put it back to factory to be "safe" or whatever. Maybe until they are blue in the face if they're that type.paul2005tb said:I just called a local Chevy dealer, the service rep said they would not do a front alignment on a Chevy vehicle with a lift.
So I talked to a few places and finally walked into my local Pepboys where I buy allot of my parts.HARDTRAILZ said:My buddy owns a dealer and sells tons of lifted truck and they service them all...even what they did not lift or sell. Forget that dealer and find a decent place to work with if you need something like alignment done.
