For the past two days, a buddy of mine and I tackled installing the shift kit into my 03 Trailblazer EXT 5.3L. I didn't do a majority of the under-car work because of my back injury, but I did most of the work on the valve body and everything else, buddy just put it back together. Once it was all put together, I filled the trans up with some fluid, and put it in gear. Now, the truck was up on jack stands on all four wheels, so none were touching the ground. It was 1:30 in the morning, so I put it in gear on the stands and tapped the gas a little bit, the wheel spun. So I shut it down for the night and came out the next morning and warmed it up and topped the fluid off. Got it off the stands, and now it won't move. Jacked it back up, and with the weight of the truck on stands and not the tires, the wheels spun again. So, I got irritated and climbed back under it and took the pan off. First thing I noticed was the manual valve shift lever wasn't connected. Could this be what's causing my problem? If this isn't, does anybody have any ideas on why it won't move with it's weight on it?
Thanks!
Thanks!
