- Aug 24, 2014
- 189
Hey everyone. I have an aftermarket transmission cooler setup with custom made aluminum AN fitting adapters that came with the kit however I will need to replace the hoses installed last year soon as I found out they are not temperature rated and routed poorly.
I was wondering if I would be better also to replace the fittings with some stronger off the shelf components as an improvement (also had previous leaks) such as -6AN 1/4" NPS fitting connected to a 90 degree AN adapter for the radiator return port and the Dorman 800-606 transmission line connector for the barbed return pipe connected to a 90 degree NPT female to female coupler and then using an NPT to -6AN adapter to that.
Also for a cooler in front of the driver side of the radiator, where is the best place to route the hoses? The left hose is hanging down far enough to be hit by snow if I drive through it. Thanks
