I had the A/C compressor bearing go on my 2002 Envoy.
I replaced the bearing but the clutch is slipping when engaged.
The clutch surfaces had quite a bit of wear on them, I cleaned them up before reassembly.
I could easily turn the compressor shaft when I had it apart with my hand and it seem to function OK which is why I decided to replace the bearing.
It must have gotten very hot as I had to clean up a lot of the black epoxy that I assume from the coil.
I check the coil and it was about 3.8 ohms so I think it should be OK
Questions:
Can the clutch be adjusted ? If so how?
Can I just get a new Pulley, Clutch and coil for it.
I didn't see any specific parts on ebay or elsewhere on the web but they reman the compressor so the parts have to be available some where.
I could not see any visible numbers on the unit but I believe it is a Sanden Compressor
Thanks!
Questions:
Thanks!
