2002 GMC Yukon XL, 6.0L. So, today I found the rear bolt that holds the oil cooler lines to the oil pan above the oil filter is stripped out in the oil pan. Has anyone installed a heli coil or maybe put a longer bolt in? Are these holes drilled through into the pan or are they blind holes? I'd like to try and fix this without pulling the oil pan if possible.
