Ok so looking thru a lot of these I haven't found out my issue. Btw, brand new to the forum here and just got my 04 envoy last weekend and 4wd didn't work. Nbd it's a Chevy and they have issues... he said he took it to the dealer and code for shift motor was bad. (No idea what code tho)
Anyway, My issueis this. My switch is stuck on A4WD. However, I can spin the rear tires with ease. No front lockup. Turn the switch either direction, no change what so ever. Jack up front tire, spin it and driveshaft spins. if I pull #8 fuse it unlocks. And tire spins freely. (Actuator is good)
Also when I plug fuse back in it locks back up. All lights on switch flash on startup, if I put the switch on 2wd, 2wd flashes and I hear encoder motor shift, but right back to A4wd on the switch. Turn switch and nothing happens.... back to square one.
I replaced shift motor with new one and exact same results. If I take the motor off and move selector I can feel what appears to be 3 settings. Non of which lock up the driveshaft, it constantly spins free.(tried neutral and park in all settings)
I replaced tccm and switch with junkyard parts just for grins with no change what so ever.(luckily they let me return them) someone had replaced mine already with a doorman tccm. It is possible the junkyard one was bad but having the exact same issue as mine doesn't seem likely
So I'm dreading that it's thetransfer case. But at least it would be fixed IF THATS THE ISSUE! Wiring looks good around t-case. Someone has replaced the tan wire from motor to connector by fuse panel. But it looks fine. Haven't put a multimeter on any wires yet.
So if it's the t-case, fine I'll buy one. But since the selector shaft moves I feel like it would at least show different modes on the switch. Maybe not but can't be sure. I really don't want to put a new transfer case in and have the same issue.
