I realize this is a really old post but just wanted to add that I believe this issue is being caused by the dining circuit in the dash which works fine for incandescent lamps that were the original lamps but the aftermarket LED’s would require an on board circuit like PWM to make dimming possible. It’s quite likely that is the source of the interference reported TPMS circuit. The switching of the diode (a nonlinear component) would be quite suspect and since removing the LED, it appears the issue was resolved.Probably just one particular brand or type that causes it and there are lots out there.
