I can't reproduce the squeal when parked. Not present if I hold down breaks and put it in gear then increase RPMs. Only happens when under load and up to speed. Starts at about 45 MPH and gets worse as speed increases. if running 60 and squeal is constant and I let off the accelerator to coast it stops.
Replaced belt first, noise still present, then tensioner and replaced belt w one another cm shorter to be sure.
AC compressor and idler are out of the configuration. I only have power steering pump and alternator in the loop. I have never had either of those squeal before. I have replaced the PS pump a cpl times over the years but never the alternator. i know I have pressed the pulley on and off of the PS pump when I replaced those.
You guys ever had a PS pump or alternator squeal when motor is up to speed and going down th road? Or should I be looking somewhere else and i'm barking up the wrong tree, completely?
