- Feb 8, 2014
- 5
Last year I let my son borrow my 2003 Trailblazer (4.2L LT EXT) to go to the hockey rink. He called me from a gas station saying it was 'smoking' and smelled like it was on fire. I go to find it appeared oil was leaking on the block. At the time it was negative degrees and the truck was parked outside. I took it home, topped off the oil and had no further problems.
No problems in the Spring, Summer or Fall. Now this winter. The truck is garaged all the time when not in use so again no problems. It snowed several inches here two days ago so I let me wife take it to work rather than her Saturn. It was -11° that day. The TB was parked in her work parking lot for 8 hours. She comes home and says the TB is burning. I go out, open the hood and see smoke coming from the left side of the block (from my perspective looking in). It looks like a stream of smoke both high and low. I check the oil. Not a drop on the dipstick. I asked her if there were any warnings or beeps during her half-hour interstate drive and she said 'no, it drove fine'.
I put three quarts in. Two days later in the garage, I take it out. I still smell the burning and notice a huge puddle of oil on my garage floor. 18" x 12" puddle of fresh oil. I drive to the gas station and purchase more oil. I check dipstick before I put it in and it shows the oil is topped-off. It appeared it hadn't leaked any of the three quarts I put in.
I can only assume the oil on the floor is leaking from when my wife brought it home. The oil I put in seemed to still be there and the puddle was probably from when my wife brought it home.
So it seems the hemorrhaging of oil only occurs when the truck is sitting in freezing cold weather and driven. Is there an explanation for that?
Through the entire ordeal, the gauges and warning lights showed no sign whatsoever of anything wrong. Minus the smoke and smell, the truck drive perfectly and the oil pressure gauge maintained a normal reading. No warning on the display of 'stop engine now', etc.
What is happening here? Thanks for any information.
