- Apr 12, 2012
- 215
This is the one I got from an auction. The noise goes away at anything over 560rpm. Before I run it back through the auction, what do you think this noise is? Sounds almost valve train related. I also know the 02 is prone to piston skirt failure. I drove this all the way from the auction. Noise is there basically only at idle. I replaced the oil and no change in sound. Would a bad flywheel make this noise?
