My rainier has failed emissions test again. replaced all secondary air system [,pump, check valve, relay] 2 years ago when it failed . I now have same problems again . Checked pump works fine off 12v source , no water in lines check valve should be ok , replaced relay and checked all fuses ok . Pump still does not start up on cold start . Also replaced o2 sensor at exhaust manifold . Any one have ideas . Thanks Mike .
