- Jan 18, 2014
- 4
Hi GMTnation! I have been doing research on the 4wd system of the trailblazer/envoy etc for about two weeks now trying to narrow down my problem. Originally, the A4wd and 4hi were acting erratically on my 02 trailblazer, sometimes working sometimes causing dash service 4wd light to come on. Then over a period of about 5 days the system failed and the lights on the selector switch wouldn't illuminate after the 2 second initial start up. For the last 7 days I have been doing research on this site trying to narrow down what my problem could be. Yesterday morning I got in the trailblazer started it up and no service 4wd light on dash and the 2wd light on the switch illuminated. Switched into A4wd and then into 4hi, they worked. Tried switching out of 4hi to 2wd and the system failed again. Replaced with known TCCM, same problem. Checked front axle actuator, it was covered in grease and sand, pulled it and connection pins looked great. Nice and clean. Then I inspected the wiring near the axle actuator and noticed the brown wire was cut pretty bad. I was so happy that I found this problem as I thought it was my problem. Not quite. Soldered wire and replaced actuator, same problem. I thought it would be fun to check the encoder, so I pulled it and inspected wiring. Looked fine. Put it back together, not fun at all as I couldn't get the shaft splines aligned easily. Also, the shaft coming out of the transfer case for the encoder would not spin more than 10-15 degrees.(should I be able to rotate this?) I then pulled the cover off of the encoder motor and rotated the internal gears until I could get the female shaft splines close to where I thought they would go on and then I reassembled the motor and installed, after aligning splines better it slid right on, imagine that! Plugged it in and checked for 4wd operation. Now no service light and the switch flashes continually as if the its trying to engage into A4wd or 4hi, then goes black, if i try to switch modes after it goes black it flashes is that mode for a while then stops, black again, try another mode same thing. The red N light is on constantly now but it still rolls drives in 2wd. It will not and I don't hear the encoder trying to turn, or turning. But I couldn't hear it before I pulled it either.
Is there a way to bench test the encoder motor?
Any other ideas?
This is my first post, this community seems awesome!! Thanks in advance!!
Transfer case fluid was changed recently and condition looked acceptable for being 55,000 old.
Any other ideas?
